Satnav problems
Grotbag1
2015 C220 Estate Sport Premium and 2005 CLK 200K Avangarde Convertible
Hi all, I am not a new member but forgot my password and don’t have access to my old email so I had to create a new account. Grotbag1. I used to be Grotbag
i have a 2005 CLK.
The sat nav works but I cannot enter a new destination as it appears locked on Borehamwood
If I try entering a new postcode if always starts with the borehamwood postcode in light grey.
The only way to select a near destination is either to zoom in using the map or use a pre saved destination.
Any ideas please
Sounds like it’s frozen and might need a reset. Find the appropriate fuse, pull it for a few minutes then put it back in. You may lose any stored data though
Hope that helps
G
Grotbag1
Thanks John
The other problem that may be linked is the clock on the dashboard is not synched exactly to the Command clock. It is 1 hour 40 mins ahead. If I change the clock time on Command, the dash clock also moves but still remains the same time ahead.
Rather than pull the fuse will it help resetting the system on Command?
Regards
Richard
Start with the Comand system reset yes Richard if that works, fuse as a last resort really.....
G
Grotbag1
I have Found a workaround. If I go into satnav and it defaults to Borehamwood, select Country and scroll to Great Britain, I can then select any town!
