Screen wash fuse location? (Viano 2012)
Swiftviano
New Registration
Viano 2012
Hi all,
Im out in my 2012 Viano today and the wind screen wash jet is not working; the headlamp wash jet is working.
Does anyone know which fuse is for the screen wash jet? I can not find it in the manual.
Any help much appreciated.
swiftviano
mioba
Nottingham and Köln
will be the same pump I imagine, have you checked the pipework hasnt come undone to the screen nozzles....
EmilysDad
Bury Lancs
ML350
I doubt it .... headlight washers usually use a higher pressure pump
maybe .... I've had similar when a heated nozzle rotted out & allowed most of the screen wash out under then bonnet rather than through the screen wash nozzles.
EmilysDad
Bury Lancs
ML350
Hi all,
swiftviano
Can you hear the pump when trying to wash the screen? A mate of EmilysMum had no screen wash on her car .... the pump was running but no screen wash to the screen. She's been using washing up liquid! Consequently the pump was trying to suck through a load of gunge in the filter.
M80
Derbyshire
The reservoir has 3 pumps. I see no individual fuses.
From that I assume each pump is fed from the SAM.
I would unplug, cycle the ignition, and check at the pump for 12 volts when initiated.
M80
Derbyshire
From an earlier than 2010 639, but the differences are negligible.
