Side trim and stickers off!!
Probably look better with a black strap... :rolleyes:
Looks better without the stickers to me
vtaylor78
Northamptonshire.
E350 CDI Coupe C207 2010 \ SLK 250 R172 2011.
I like it , a much better look, I’ve done exactly the same to mine.
John Laidlaw
Wirral
Land Rover Discovery 4
Deffo better - smooth and clean. Looks great
Naraic
2005 CL500.
Much better...now just raise the rear to equal the front and it will be perfect.
A.J.
Norwich. UK
That is so much better, this is only my opinion but I do like to see a bit of chrome though :)
Srdl
Hampshire
GLC43 AMG 2018 (X253)
It’s a “much better” from me too ;)
Craiglxviii
Cambs UK
Agreed, much improved.
SmartAmg
SmartAmg
2011 E class coupe 350 CDI
I assume the trims are just stuck on and removing is simple?
They are just stuck on, removing is simple'ish, i warmed the trim with a heat gun, then got some fishing line and sort off cheese cut behind the trim,
warming the trim as you go along, that's the easy bit.
You are then left with the two sided tape still on the car, i sprayed it with WD40 let It soak for about 10 mins
then got an old credit/store
card and scraped the tape off, it's time consuming but it works, and doesn't scratch the car, you are then left with just the glue ,
you can use WD40 again but I found petrol works better, then a good polish to finish off, sounds a bit long winded but it does work.
Srdl
Hampshire
Looks much better, I don't see the need to stick fake chrome on cars
I think the chrome trim was original - certainly had it on my C207
