yelnats69
- Sep 1, 2018
- SL350 2009. Sprinter Autocruise camper 2001
First off, a couple of question about the boot, as I feel they might be related to the roof problem .
Boot does not open under power.
when (button(s) are pressed, you can hear the unlock, disengage but boot has to be lifted manually.
boot will close very efficiently via power button(s).
Does it close simply by gravity (seems to be powered down, and its pretty heavy? ) if it is powered the the hydraulic pump , then 1 stage must at least be working.???? cant hear the pump
Now onto the to the roof.
when open roof is selected, windows drop and i can hear some (locks?? noise) but no pump sound and no other movement than the windows. windows will raise on on close roof.
So any advice would be deeply appreciated
Stan Stockdale
SL350 2009 face lift
Stan Stockdale
