Sl350 roof problems
DansE320
Newcastle upon tyne
2004 E320 Estate S211 2007 sl350
Hello, not sure if this is the correct place to post......
I have just bought a 2007 sl350.
When I try to open the roof, the boot opens about 6 inches, I then have to release the operating switch and pull again, it opens another cple of inches, I repeat and it opens another cple inches, but then stops all together. It's very slow to open this much ( about 2 minutes). Any thoughts? Thanks
s5tuart
2003 R230 SL350
There's a strict sequence of things to move and operate various switches for the roof to open
On my SL the flap motor had got out of sync ( so I'm told) so the roof wouldn't move from halfway open.
I'd close it again if you can and visit an Indy
D
DansE320
Newcastle upon tyne
Thanks, does anybody know a good indy in north east ( near Newcastle)
ajlsl600
france
Somewhere in here there is a repair story on flap motor gear drives which I suspect is Yr issue. Hopefully someone will be able to point you to that.
D
DansE320
Newcastle upon tyne
I don't think it gets far enough along the cycle, boot only opens about 10 inches and takes a couple minutes to do this
Whoever sold it , dealer or private they are liable for the fault .
An icarsoft code reader will show any sensor fault codes for the roof fault (£100-150?)
rf065
Grossbritannien
Have you tried giving the boot a helping hand while someone operates the switch?
Our SLC used to stop before the boot was fully opened, I gave it a helping hand, as well as working the boot lid back and forwards to make sure it was not something sticking and it worked perfectly from then on.
D
DansE320
Newcastle upon tyne
Thanks for the advice, I haven't - was a bit worried about breaking something. Will give it a gentle pull
00slk
Cambridgeshire UK
Check the boot battery condition, will need to be at least 12.6v.
I had this same problem buying my R230 when I viewed the car. It was the battery.
star
Reading
Smart + others :)
Checked the oil level?
D
DansE320
Newcastle upon tyne
  • #17
Yes, oil is fine. Wondering if it's a bypass of the trunk lid drive cylinder as pump motor seems to be working overtime.
D
DansE320
Newcastle upon tyne
  • #20
Just wanted to give an update incase anybody else has been suffering similar issues. After performing some tests for internal bypass ( none) I decided it must be a weak pump. Before biting the bullet and spending hundreds on a replacement, I drained the hydraulic fluid and filled it with new ( not expecting it to fix the issue) but to my utter amazement, roof now works. Thanks again to all who replied. Hopefully this may help somebody
