SL500, R230 roof flaps only opening half way
Miracle
Sl500 , R230
Good day
I have a 2002, sl500, R230 convertible with the roof openning half way but when the roof flaps try to open, they are both only openning half way and then the roof operation stops.
Anyone who knows what it can be???
Please help
Good day
Please help
Probably a faulty sensor , you ideally need to get the car scanned for fault codes .
Where do you live so an MB specialist can be recommended to you (hopefully)
s5tuart
2003 R230 SL350
Mine needed a new flap motor :(
ajlsl600
france
As above, sensor or plastic gear on the flaps? Research r230 roof flaps, sure u will find something on here.
SL63 Mark
The South
R231 SL63 AMG
It's likely the gear on the flaps. Very common failure on R230. it is a DIY fix. I did mine, so it can't be too hard.
M
Miracle
Sl500 , R230
Thank you...i live in Cayman islands
Will check around for good merc machanics
NJS5
Catherington, Hampshire.
2011 R230 SL350, 2016 Discovery 4 Landmark, 1973 MG B GT V8, 1959 MGA roadster.
Mircale
It might help if you were to update your profile to show your location as "Cayman islands"
Good luck.
NJSS
Catherington
www.W140.co.uk&www.r129.co
