- Mar 14, 2005
- Age
- 89
- Location
- Daventry
- 2002 SL500, 216 CL500, all fully loaded
I think that the exhaust has to come off anyway.
I started the strut removal today however I'm a little stuck
I have removed the 18mm nut to Detach the spring control arm from the rear axle (6a in diagram) but I am not able to remove the bolt it doesn't budge.
Any ideas?
I have never removed that bolt nor exhausts to swap a leg out, have you looked on WIS Malc???
Hi sirWell finally got the strut fitted and........
All looks good, took the car a run and no errors hope that's it fixed.
Resurrecting an olllld thread here…Hi sir
i have the same problem with my car
c1526-008 right rear valve stuck
you finally changed your rear right strut and you said you hope the problem is over.
Did your problem go away when you changed the strut ?
I am waiting for your answer, I suffered a lot to solve the problem.
I'll be happy if you can help me
Mb-specificResurrecting an olllld thread here…
What system are you using to get the error code? Is it generic or MB-specific?
In that case, you need to remove, strip, clean and replace your rear valve block. Luckily not a hard or expensive job. New o-rings should be c.40£Mb-specific
Error code c1526-008 which is y36/2y3
