SL55 supercharger bearing replacement guide, save yourself £2200!
Goliath
Bristol
'03 SL55 AMG
The supercharger pulley bearing on my SL55 needed replacing as you can see:
I got a quote from Mercedes for around £2250 to do the job. I much prefer to work on my cars myself so I know the job has been done properly so looked into doing it myself. It can be done easily and quickly, it took me less than an hour with no specialist tools.
Step 1: Order a new bearing, Nachi part number is 45BG07S5DL and costs about £80 or PFI do one for about £30 (http://www.ebay.co.uk/itm/132090277071). I opted for the PFI bearing as it would arrive much quicker than the Nachi one and I need/want to use the car asap. (delivery took less than a week).
Step 2: Tools needed are.... 17mm 12 sided socket/spanner (to remove belt), 24mm socket (to undo pulley bolt), Hose/jubilee clips (130mm or bigger), pliers or circlip pliers, hammer, torque wrench, an oven and a freezer!
Step 3: Remove belt by loosening tensioner with 17mm spanner/socket (12 sided)...
Step 4: Place hose clamps as shown to clamp the supercharger still, do them up tight! (this could scratch the black paint)
Step 5: Use the 24mm socket to undo the supercharger bolt:
Step 6: Once the bolt is out the pulley just slides off with the bearing inside it, then use the pliers/circlip pliers to remove the circlip:
Step 7: Turn pulley up the other way, suspend on 2 blocks either side, place the big washer from the 24mm bolt on the bearing along with the 24mm socket to act as a punch and then tap it with a hammer to remove the bearing from the pulley. It doesn't take a lot of force to remove it.
Step 8: Place the new bearing in the freezer and the pulley in the oven for 15 minutes at 200 degrees (or until golden brown... joke!).
Step 9: Remove new bearing from the freezer and the pulley from the oven and immediately slot the new bearing into the pulley. It should slot straight in, if not will only need a gentle tap with your hand.
Step 10: Refit circlip, then refit pulley onto the supercharger, tighten with a torque wrench to 40 ft/lbs and using the circlip trick above to hold the supercharger still. Don't forget dab of threadlock on the bolt.
Step 11: Refit belt, hey presto, job done!
Now the car runs beautifully and the supercharger pulley is nice and quiet!
Goodness only knows how mercedes can charge £2250 for a £30 (or £80) part and 1 hours labour.
There is a video here (not mine) showing all these instructions too:
https://www.youtube.com/watch?v=TQsVok6BC50&t
flowrider
SL500 (R230)
Great write up, this is going to save some people a huge amount of money.
As above, nice write up ....
I assume Mrs Goliath was out at the time :rolleyes: ;)
Naraic
2005 CL500.
£2200...probably a replacement supercharger.
patxi
Berks
S212 E350 Estate
Excellent write up - should be moved to DIY section and pinned
Craiglxviii
Cambs UK
This is a really good write up and a great idea. Thank you.
Now I just need a CK55K...
G
Goliath
Bristol
'03 SL55 AMG
She was in and thought I was cooking dinner for a minute until she looked! She is used to it though, before now she has opened the dishwasher to find a wheel just finishing off!
Nope, they wouldn't replace the bearing alone so would replace the pulley (so even less labour time). The whole supercharger is about £5,500 from mercedes!
She was in and thought I was cooking dinner for a minute until she looked! She is used to it though, before now she has opened the dishwasher to find a wheel just finishing off! ....,
They say dish washers are good at cleaning cylinder heads ..... I've never been that brave. ;)
...Nope, they wouldn't replace the bearing alone so would replace the pulley (so even less labour time). The whole supercharger is about £5,500 from mercedes!
Wow! :shock:
bembo449
gainsborough , lincolnshire
this is the kindas thing that makes being a forum member worthwhile , great "how too " pal , top work :D
AMGeed
Poole, Dorset
S204 C180K
The dealers are really taking the P wanting £2.2k to change a pulley!
There are so many people upgrading their std 90mm pulley for an 84mm or 77mm that there are a glut of 2nd hand ones.
An uprated 84mm one is around £400 plus less than 30 mins to fit.
Anyway, nice write up and glad you sorted it yourself.
