SL600 r230 ABC oil leak
peter dunnett
Colchester Essex
SL 600 2003 5.5lt
My SL600 has just dumped a load of Suspension oil on the drive, I removed the off-side front wheel and liner it looks like the oil has been ejected through the ABC bleed value.
A couple of weeks ago I noticed it looked like oil had been ejected out of the header tank as if the system had got pressurised in some way.
Any ideas about what could be the cause?
peter dunnett
peter dunnett
Colchester Essex
SL 600 2003 5.5lt
  • #2
After further investigation the pipe from the suspension leg to the regulator has sprung a leak it looks like it has corroded and split any recommendations on where I can get a replacement?
Richard Moakes
Newton Abbot, Devon, UK
CL500; ML500
Hi Peter, it’s likely that only a Mercedes dealer will be able to supply a pipe, or a good hydraulic supplier might be able to repair it with a section of flexible high pressure hose.
ajlsl600
france
My Vdoz had a weeping pipe at block in rear of p/s wheel arch, pipe about a ft long, was 105 ukp from benz.
ajlsl600
france
U shud be able to use an online pts list
Most 230 abc lines are NLA from MB. The rears are definitely.
