rich.g.williams
- Oct 25, 2009
- Location
- Cardiff, South Wales
- C200 Kompressor Coupe 2003
For a while there has been a problem engaging Drive (First gear) from Neutral. Sometimes there can be quite a jolt when Drive is engaged. There is no discernible pattern except that this happens after a run when the engine and transmission are hot (never when the car is cold). Everything else about the transmission seems normal.
The car is my early 2003 C200 Kompressor Coupe (CL203). The transmission is the 330Nm version of the 722.6, the car has done 45K miles. I have worked on these transmissions before without much success but I have a basic understanding of how they work and have read up quite a lot about them, I'm attaching a diagram that may be useful to others.
Any ideas about what might be the cause of this random jolting from Neutral to 1st gear would be much appreciated. PS if I put the transmission on the W setting rather than the S setting it still can jolt.
