SLK - permanently locked arm rest compartment
It is vacuum locked, not easy, need to think
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Is your SLK a R170 or R171?
jib
jibcl500
Cambridgeshire
CL500,ML55,SLK280
My r171 as ive just had a look, the lid needs some pulling to open it, place fingers on both sides on the tabs in the holes and lift with some force.
jib
I think it will be a 171 Jib and not vacuum locked, I was wrong on my above post, its an electric catch 65
index.php
H
Herbster
Sheffield,south Yorkshire, uk
Slk/2009/200
Hi, thanks I tried lifting it as suggested by Jib but it still wont budge! If I rest my hand on top I can feel the lock doing something when I lock & unlock it.
At this stage I would try a knife to see if you can unhook the latch, then one can see what is happening
H
Herbster
Slk/2009/200
Thanks guys, I opened it with a knife & all looks OK, catches nice & free etc. However I then closed it again & it still wont open !!! Guess I'll have to keep the knife in the glove box !
You can replace the lock, I can work out the details for you to change it
Andy.M
Rochester Kent
2014 GLA250 Premium Plus, Night, AMG Exclusive Leather, Driving Assistance Packs COMAND DAB HK Audio
Just thinking outside the box, if its all working when open, hows the hole it locks into looking?
I do not know yet what way this box locks, it could just be a broken spring
Monday
Surrey
SL400 2016, CLS350 2020
No consolation I know, but I had two of these boxes/lids changed under warranty on an R171 SLK280. The lock kept jamming exactly like this, must be a weak point somewhere. MB solution is of course to throw away the old one and replace with a new one!
ionod55555
I have the same problem, can hear the lock but nothing happens. Where do I put the knife to release it? Help please!!!!
He was last seen on the forum 6 years ago buddy . But maybe someone with the same car can send you a picture of the mechanism inside which might allow you to think of a solution
ionod55555
Many thanks Wighty, I don't want to force it, just bought the car so want to avoid damage just yet..
The centre armrest box requires some force to open it. You get used to it though.
The outer 2 are the catches
View of the inside of the lid
