SLK PSE Pump!!!!!!! Rotten
jibcl500
Cambridgeshire
CL500,ML55,SLK280
All
Just removed the PSE pump from the wifes SLK as the roof was becoming a hassle. This is what the PCB looks like after several years worth of moisture.
Hope that soldering some of the joints will fix it, then I will replace the pump but in a sealed bag with cable ties.
see pics
jib
I will always solder up and re do the board for you, its up to you and free
jibcl500
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Thnaks for Malcolm, very kind of you. Ive just resoldered all the joint that look rough, here goes, will get back to you in min or two.
jib
You must spray the board, use a clear celulose both sides
jibcl500
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Malcolm
thanks for that, I had a can in the garage so gave it a good spray.
jib
Did you turn the PSE upside down ?
It can be fatal to place these things in a sealed bag,as if water gets in it cant dry out. Water finds its way into strange places
jibcl500
jibcl500
Cambridgeshire
CL500,ML55,SLK280
No Ive refitted the PSE as originally fitted, I will look at a way of sealing the PSE without turning it upside down. Ideally I need to find out where the water is coming in from and try to do something about that as the foam box stays damp.
See attached 3 of my brood, I will be building a bigger garage next year to take 4 cars.
jib
I understand that the water runs down the cables
wireman
lancashire
Clobber the gubbins with waxoyl, it has kept a several electronic modules I have installed in very good order for the last ten years.
The units are pole mounted (inside boxes) on a coastal spot with high & wet sea winds.
The aerosol can works quite well and is easy to apply an even coat with.
www.ckinsurance.co.uk
