SLK230 roof opening issues.
Keur
SLK230 2dr Roadster 1998
After having some problems with the roof opening I was told by my MB dealer that the issues related to the hydraulic pump. I replaced the pump with a recon and solved the roof operation except on closing it fails to close the quarter and side windows. Any suggestions? It is a 1999 kompressor model R170. Thanks
NJS5
Catherington, Hampshire.
2011 R230 SL350, 2016 Discovery 4 Landmark, 1973 MG B GT V8, 1959 MGA roadster.
Welcome Keur
Sorry I can't help - but hopefully someone will be along soon.
Your profile is incomplete - where are you from please?
NJSS
Brian23
EClass
The problem is that the pump sits in a foam box and get water in it and it ruins the circuit board. Is it dry?
K
Keur
Welcome Keur
NJSS
Thanks mate. I am located in Australia
K
Keur
Thanks for that. Never gave that a thought as it worked initially. After reading a few replys with similar problems I assumed it was probably a micro switch sensor issue. Where is the switch for the the final stage of closure located?
ajlsl600
france
Also check door catch switches these brings windows up last inch after telling brain that doors are closed
www.W140.co.uk&www.r129.co
