Bonehead
- Oct 17, 2014
- Location
- Bristol
- Sprinter 311cdi/2003/2.1L turbo
Hi all,
I having a problem with my 2003 Sprinter 311 cdi that seems to crop up on this forum and others. The main issue is that the engine will cut out whilst driving - usually after having driven the van for while that day (i.e. the engine is warm). When the problem occurs i have to pull to the side of the road, turn the key back, and then restart. It will restart fine but 10 minutes later the problem will happen again. I can usually start it one last time but if the engine cuts out a third time i then can't get it started at all and EDC light comes on. The engine doesn't even try to turn over.
In addition to this i have had some problems starting it on occasion. Easystart will get it going but i imagine the 2 problems are somehow connected.
On taking it to my mechanic each time the cause he has shown me has been a cracked washer in the fuel pressure regulator/valve and all error codes point to the fuel pressure valve. I have had the valve replaced twice but the problem persists. I have just broken down again and so want to take it to another mechanic (preferably a merc specialist who has seen this problem before) to get the error codes read and the problem properly diagnosed.
I read a lot the problem could be the CPS - but will this crack the fuel pressure valve washer? Could anyone shed any light please? If it is the CPS then i could replace this myself so i am told which could save me a lot of money.
I live in Bristol if anyone could help me locate a trusty independent merc specialist?
Please help.
Andy
Please help.
Andy
