Sprinter 313 cdi 2007 engine code p1955
Steve7311
Mercedes sprinter 313 cdi 2007
Hi. I’ve not had my sprinter long when the engine light came on and went into limp mode with the code p1955 ( glow plug module 2 to pcm comm) . I decided to start replacing parts like the maf sensor, air in take sensor, glow plugs, glow plug module, egr valve. The code will not clear still ‍♂️ has anybody had this problem and fixed it?
Many thanks Steve.
Steve7311
Thanks trev. I’ll look into replacing the throttle body and pressure sensor. I hope that sorts it
Trev1964
Lydney
CLS 250 cdi estate 2013
What I took from that article was you should get the codes read properly..
Larkone
NW Essex
C219 CLS 320CDI 2008
If you are randomly changing parts rather than getting the codes read properly then this recommended
