Squeaky Steering E240 (W210 1998)
Dosco
W211
There is what I can best describe as a 'dry rubber seal squeak' as I turn the S/wheel either way, even turning the wheel an inch or so either way causes this annoying squeak.
Any ideas :confused:
Do check your bottom swivels easily tested by jacking the front of the car
D
Dosco
W211
I hope its what Malcolm says - mine (yr2000 E240) needed a new rack to shut it up.
Do also try a bit of lube on the rubber supports under the dash.
Bit overdue this response but checked the bottom steering links/swivels etc so it seems it is either of the two suggestions made by yourself:(, In getting at the rubber supports is there anything I need to be aware of and if that fails what sort of cost etc for a replacement rack, given that at present I am unable to do this myself :(:(
With the front of the car jacked, you could possibly hear the steering swivels by putting a large bladed screwdriver onto each joint and the handle to your ear, and turning the steering, swivels are a 90% failure as apposed to the steering racks
D
Dosco
W211
I can tell which school of engineering you went to Malcolm;)
Its a wonderful way of differentiating between tappets,and timing chains and water pumps
Get some of these from a Vet, the ones they stick in horses, you can fill them with oil and inject through the rubber boot
D
Dosco
W211
Vet did not believe me when I told him what I wanted to stick them in however all is Okay found some in the park along with one finger rubber gloves now about that stetho thingy......:p
Good tool shops sell them, they are used for injecting glue etc:D
