SRS Issue
RANA_1
SRS Controller was diagnosed as faulty and changed.
Now two new codes have turned up.....
B1869 The resistance value in the ignition circuit containing component R12/11 (Left rear side airbag ignition squib) is too high.
B1873 The resistance value in the ignition circuit containing component R12/11 (Right rear side airbag ignition squib) is too high.
Any ideas on how to check this ?
star
Reading
Smart + others :)
Check that your rear seat belt stalks have retracted, has it had a bump?? The stalks shud sit proud of the rear cusion.
Ellsy Tanners
Mars
It could be that you dont have have rear side air bags and they need to be coded out.
R
RANA_1
Thanks.
I am not aware of any accidents.
There are no signs of "SRS AIRBAG" labels in the back roof or in the doors - does this mean there are none fitted.
Can you please explain the stalks statement - not sure what to look for.
R
RANA_1
OK how do I prove this ?
If the SRS controller was coded for no rear air bags and it still fails then this to me mean it is a fault with the controller. Is this logical.
Ellsy Tanners
Mars
Possibly but i doubt it, get it checked and coded and let us know if it still comes up with a fault, i would be amazed if it does!!!
R
RANA_1
Booked back in.
According to MB against the VIN number there are curtain airbags fitted, no signs in the cabin though ?
I'll ask for the coding to be checked again and identify what has been coded.
Will update post this.
Ellsy Tanners
Mars
Those fault codes are for the side airbags in the doors which it sounds like you havnt got fitted.
R
RANA_1
Yes, correct, I don't have these airbags, checked with the original dealer they were never fitted.
Can you advise how you have concluded the airbags these codes refer too ?
Ellsy Tanners
Mars
R12/11 That is the terminology mb use for the side (door) bags. R12 is the mb designation for a airbag or seat belt tensior and 11is which one. all the airbags on the car have a different number R12/--.
The discription also tells me it is reffering to the rear left and right side bags.
This and over 10 years experience!!!
R
RANA_1
Hi, I'm not disagreeing, just making sure I can challenge what I am being told.
R
RANA_1
Code corrected, all well, full steam ahead :) for the next adventure
Tel: 020 8863 9233
