Steering
Nigelbilly
2003 c180 kompressor
Hi .
New to this forum.
Need some help if possible I have got a strange noise like scraping when I turn my wheels to the right and when going in a straight line it's there but not quite noticeable and nothing when I turn left.
Any help would be great.
MercSLK
South Ayrshire
SLK320/2003/M112
Hi .
New to this forum.
Front wheel bearing?
N
Nigelbilly
No
Checked them sounds like pads against the disc but I have put new spring on as I had snapped new pads new sick.
N
Nigelbilly
Sorry
If checked bearings all ok.
It sounds like brake pads rubbing ?very loud).
It did have a broken spring but i have changed that along with new disc and pads but still making this noise
MercSLK
South Ayrshire
SLK320/2003/M112
Sorry
Is the noise coming from the back or front of car? Which end of car did you renew the spring? I take it you are talking about the road spring? Which end of the car did you renew the discs and pads? Did you use OEM parts?
N
Nigelbilly
Front passengers side coil spring
And front discs and pads but they are all ok when free wheeling the wheels on axle stands
N
Nigelbilly
No
No mud flaps that was first thing I checked for
Sometimes can be a bit of debris lodged between the hub and wheel. Try reversing the car fairly quickly then sharp brake....obs when you've a clear space like in a car park or...
As John says a stone caught between disc and dust shield can cause scraping noises. Also many years ago a friend of mine managed to install his new pads so one was the wrong way round (i.e. the friction surface was towards the piston!). Its a long shot but have you checked...?
Finally on some brakes there is a spring spring clip sits between the pad retaining pins and pads - this can sometimes slip down between the pads if not installed correctly.
