dursleyman
- Dec 17, 2006
- Location
- Dursley, Glos
- 2005 E220CDI Elegance Estate, 1977 Triumph TR7 FHC, 1980 Triumph TR7 DHC
Trim and buttons can do that, if y can get it off I’d wash and clean it until the stickiness goes. Might lose those light switch labels thoughThe piece of trim around the light switch on our 2005 W211 estate has gone "sticky". Is as if the plastic surface seems to be breaking down?
Anyone else had this?
Like new but without the rubberised coatingOn my W221 the steering wheel buttons had the same issue. I used a rubbing type alcohol here called Isopril, rubbed it on with a fibre cloth, let is soak for a couple of minutes then gently rubbed off the stickiness, couple more repeats and the buttons are like new. No damage to the original item patterns. Good luck.
