Strange Command Problem (map not visible)
mjbarnard
New Registration
07 E320 CDI - although running 5.1 command software.
Very strange map problem. Recreated it last four days.
Map and sat nav work fine. On returning home from work (along A40 in London) when I reach the exact same place the map goes blank. Only grey background. However the central icon carries on working and changes direction with the car. The instrument console continues to show the correct location and direction.
The instrument console continues to work wherever I go - even places that subsequently show the map fine. If the nav function is used (even when the map appears greay/blank) it also functions correctly with the right hand side showing appropriate directions, instrument console working, and correct audible directions.
So the map is being read, but simply doesnt show.
The wierd thing is that I noticed the map blanked out at the same point on my route. So today I watched the map as I approached that point - and I actually saw the map on right of screen approaching blank/grey area on left of screen until I reached the blank bit - then nothing seen.
If I turn the car off, lock from outside, wait two minutes - all returns to normal! Can see the map once again, wherever I am.
Realise will have to take to dealer - but any ideas/similar problems?
Ellsy Tanners
Mars
Its got to be a software error on the navi disc, i recon they will try you with a new disc to start with.
Mappi ng faults can and do happen, problely some missing data on your disc
The only thing here is that it is ok when going the other way on the same road, so it is the same map but going the other way, its a strange fault
