Tel/Nav/Audio not working
O
oakwood101
Hello all I am a new member and would very much appreciate some help.
My Tel/Nav/Audio has stopped working.
When I go through the screens what I do get is " Waiting for Nav " or Waiting for Tel in the instrument display then just ---- four dashes. I have tried taking out the fuses and disconnecting the battery but the has not worked.
The disc will not reject from the unit in the rear. It is a Harman Becker model 6059.
My car is a 2005 E320 CDI Estate.
Any advise would very much be appreciated
It will have to go on STAR I think to see what has happened, you have done all the first checks
_Taz_
Kent
2011 E63 6.3NA AMG Tenorite Estate MCT 7g
sounds like the AGW may have failed ( but only guessing really )
O
oakwood101
Sorry to be so ignorant television but what is "Star"
_Taz_
Kent
It's Mercedes own Diagnostic software, not cheap, or easy to use. Typically the dealer or a decent independant will help you ( tons of GOOD resident ones on this forum :cool: )
You may get some sense from generic code readers, but like any code reader, the real skill is learning to make sense of what the reader tells you.
HTH
O
oakwood101
HTH
Thanks Taz. I will go to the local dealer on Monday.
_Taz_
Kent
one word of caution is that their labour rates will be high, expect a usual of ~ £100 p/hour all in.
If you look on the forum, you may find an alternative Indie who has STAR who will probably charge you 1/2 that rate.
Have you checked the fuse for the AGW module ? Fuse no' 6 in the nsr fuse rack on the boot IIRC :)
Good luck, it may something as simple as this, however if the command HU fires up, it normally mean the AGW unit in the boot is ok ( I had to exchange mine a while back as it gradually lost it's AM/FM radio... very frustrating to solve ! )
Do find a good indie near you in the "specialist finder" top right, very expensive to use a dealer
