octanejunkie
- Oct 12, 2009
- Location
- Clevedon, North Somerset
- All sorts of Germans
- Thread Starter
- Thread starter
- #61
After a fair bit of rubbing down with 400 grit wet 'n dry, i had to cover the tyres.
Lots of masking tape was required as i don't have a tyre fitting machine.
Its pretty easy to do, just take your time.
A good wipe over with some pre paint, and they were ready for a bit of etch primer. This has some sort of acid in it which eats into the surface onto which you are spraying giving the best possible adhesion. Its £12 a can so use sparingly. Its important to use this, especially on areas of bare metal, as normal primer would flake off after a time. I gave the whole wheel a coat of etch prime as wheels are a pretty hostile enviroment for paint!
its nasty stuff, so make sure you have a mask
Once that is dry, you can then put a coat of traditional grey primer on.
As you can see the wheels are looking better already!
