Tyre Pressures.
onefortheroad
uk.
I have an E220 CDI Cabriolet, staggered tyres (front/rear) 235/35/18 and 255/35/18 on the rear, and I run them all at 37 psi. On the sport edition the suspension is hard the tyres feel every stone bump however any lower and I risk cracking the alloys due to pot holes and poor road conditions.
Those tyre sizes dont seem correct. 235 x 40 x18 . Should be on the front.
Buck2003
2011 E220 CDI 2.1 diesel blue efficiency Auto Cabriolet
I have now lowered the pressures to 36 psi and it seems to suit well. Slightly more feel in the steering and not as firm on the road.
I guess being an estate it also depends what weight your carrying...luggage and even passengers or towing.
brandwooddixon
Wolverhampton
S63 Coupe 2014
A lot of tyre pressures are set by the manufacturer to improve fuel economy.
If the car is unladen with two occupants you can normally get away with a reduction of 3psi for comfort.
Just be aware that with very low profile tyres you'll be reducing their resilience to pothole damage as you reduce the pressure.
O
oldjohnny
I 2005 BMW E60 530d. 2012 Mercedes e class estate.
  • #25
I am constantly on pothole watch nowdays. Some of our minor road resemble scud missile test sites.
I hit a barstesard last week. Went out next day and tyre was flat. Its like driving on the moon.
Govt wont do anything as motoring is a huge earner, damage your car - go to garage - more nuggets to No 11
  • Like
Reactions: DSK
oigle
members.optusnet.com.au
Makes the combo of large wheels and LP tyres even more useless. I've just removed the 20" wheels off my new EV6 and replaced with 18" and commensurately higher sidewalls. Was 255/45/20. Now 235/60/18. Only query I have is "previous reccommended pressure was 36psi. What pressure should I put in new ones?"
onefortheroad
uk.
36 it's vehicle based , not tyre size afaik
oigle
Not so mate. It's related to the air VOLUME in the tyres. Bit like pushbike tyres. Skinny road tyres are pumped to over 100psi whereas fatter off road tyres run around 45. I'm just unsure whether the new tyres will have less or more volumemetric space. Guess won't be much in it so maybe stay with 36 and see how they feel.
w204benz
2012 C200CDI AMG Sport
Try this, it should at least be good for a ballpark figure: https://tiresize.com/pressure-calculator/
onefortheroad
uk.
Lol.
oigle
grayb
Kent
E350CDI (S212) 2010
I did find this a couple of years ago - a method for comparing cold to warm pressure increases and taking that as an indicator of too low or too high pressures. All to do with the friction on the air inside the tyre. We tried it with our caravan tyres and it seemed to work, giving a smoother tow.
Jmistry
New Registration
E220/2022
Hello folks, new to the forum - loving it.
I have an e220d and the ride feels stiff even in Comfort mode! Could it be the tyres? (I have 19" Pirellis). Any recommendations on what could the issue and how to solve? cheers
Hello and welcome,
Irish roads, 19" wheels and Pirelli tyres.. a combination made in the deepest levels of Hell... :eek:
Comfort mode only alters gearbox and throttle response (unless you have the fancy suspension, (which isn't common on the W213 220d)
I'd search out some 17" wheels and tyres with 225/55 tyres and sell your 19"'s
