SteveX
- Oct 27, 2009
- Thread Starter
- Thread starter
- #41
Had the battery on charge all last night. Went out and put the ignition on and off with keyless and the key.
Checked for fault codes and there weren't any...
Started the engine with the key in case, shifted through Park down to Drive and up various times all engaged and showed up absolutely fine. Shut off and checked the different control modules for codes again - all clear.
Everything on the car is working fine.
Haven't tried keyless go yet but I suspect as the shifter is working fine so will it.
I actually wonder if it was due to the low battery, as I said, when my alternator went and the battery got very low the car started to do some odd things when turning the ignition on and trying to crank, IE SRS light would come on, command wouldn't wake up, but reset itself when charge was put in and restarted.
I haven't been using the car much at all this past few months, as I have been away, then I bought a new motorbike and have been using that. As I said when starting yesterday all of the lights dimmed and and the starter was slower, I did think I should put it on charge this week but did proceed to make four short trips in it yesterday and activate the roof, so taking more out of it, it was the fifth time I started it that it went odd.
I still want to find a shut down procedure though in case keyless go lands me in that situation again. I'll also still get the tech out to get star on it and give it a good going over, might be best to replace the module under the selector just in case but will see.
