V220 2.2cdi Auto Gearbox ECU location
Hertfordhsire
v220/2002/2.2cdi
Can anyone advise on where the automatic gearbox ECU is to be found on my V220. Also I'm trying to find instructions for how to remove the gearbox as well.
Problem is gearbox stays in neutral - any ideas?
James
PS: Does anyone in Herts have a Star set up?
Did the car just lose drive, fluid level OK ?, could be the pump.
N
Hertfordhsire
v220/2002/2.2cdi
V220 CDI Auto Gearbox Issues
Hi, Many thanks for your response. The gearbox dropped into neutral while driving and car was recovered. Diagnostics (Green Flag) indicated oil low. I have changed the oil and replaced with the gold ATF. Car starts fine but when you select D, R or 1,2,3 then nothing. If you rev engine then Gearbox Warning light comes on.
The gearbox also does't get warm when I run the engine for 10 minutes.
Is there anyway of checking / changing the pump while fitted or do I have to remove?
James
