Views upon ECU remapping and brabus chip
NISFAN
Herts UK
C220CDi W204 :)
No, re-mapping only really works with Turbo charged engines. It is no rocket science, the added power comes almost entirely from higher boost pressure so not likely to make much difference to your N/A Rex.:(
What makes me laugh are the claims of earlier boost (lower boost threshold- a function of physical turbo matching), and the wild % increase that you hear for power and torque and fuel economy. And just when I thought I had heard everything, I now hear that mapping can drop your revs by 2-300rpm at a steady speed. Wow, I think the bosses of messrs Alonso, Hamilton, Button, etc would be very keen to get in touch with these engine management geniuses.
Re-mapping works well, and a ECU re-flash is the best way to do it, much better than those plug in boxes that intercept and fool the ECU into doing something different, plus as a business it is the most lucrative, as once you have cracked the manufacturers coded maps cells, you can map one vehicle and forever more cut and paste that map into hundreds of same engine vehicles. Charge £400-600 a pop for 30 minutes work, which involving no replacing of parts. A proverbial gold mine.
I say crack the code, but most of the goons out there buy the cracked code from a 3rd parties in the first place, as they aren't bright enough to figure it out themselves.
Once you have the capability to do all this, all you have to do is convince potential customers that it is not detectable (absolutely incorrect on any ECU that I know of), and that you don't have to worry about the warranty being void.
The added bonus is you can re-charge the same customers when MB (for example) re-flash the ECU with their latest maps, which happens from time to time during regular servicing, which wipes the re-map.
Now, where is my OBD cable and my laptop :D
wemorgan
R172 SLK 250CDI
I agree with some of the above, but my remap cost me £117 and I can have it remapped free if the OEM wipes it.
hawk20
ML250 BlueTEC Sport
Well said. But I doubt if the zealots will want to hear such a logical set of arguments.
st4
Banned
Sunny Scotland
1-stephen-taylor.artistwebsites.com
Disqualified driver
EVO magazine had a very good article on the "ask the experts section" re remapping....
The gist of it is was
Cars are given the standard mapping to pass very strict new car emissions laws that are passed world wide. No ifs, not buts. The car needs to be able to pass MOT tests/equivalent yearly tests as it gets older. The mapping on the car is designed so as engine ages/beds in and components age/deteriorate it is still capable of passing these tests.
New car emission tests are often stricter than MOT/equivalent. In other words the remapper has a much larger set of criteria to play with than the manufacturer does.
The technical expert went on to say that although the engines and components of cars have a large tolerance and can take the additional power (well torque) it still compromises durability as again, the factory settings have catered for maximum durability to see the car say through a 10-20year life cycle. In the remapping world this is not a major factor, but for the manufacturer it is....
The expert indicated remapping can produce better MPG as well, as it facilitates leaner running but at the expense of greater NOx emissions-failure of emissions regs for new cars.
jubhi
Birmingham
E350 CDI Sport Coupe Brabus D6-III, A150 SE, Honda CBR1000RR Fireblade
NISFAN you seem to know your stuff....
Can you explain please the main advantage of the Remap over a Plug and Play. Brabus unit is Plug and Play and so what do you think are the downsides? Only downside I see of the Brabus is the cost!!
The way I see it is at least with Plug and Play your map cannot be overwritten and you are not messing with the car's original map?
gfhowland
Lincolnshire
C220cdi (2003), Mazda RX-8 (2009)
Looks like the 'expert' answers all doubters then, a re-map is good for power and mpg at the expense of wear and tear and emissions.
Damn shame I cant remap the RX-8, a bit more economy wouldnt go a-miss... towing a tanker behind me is seriously hampering performance :rolleyes:
st4
Banned
Sunny Scotland
Disqualified driver
Increased rail pressure, injector wear and tear, rise in insurance premium.
Having had the pleasure of the V6 CDi in a 211 (so heavier and less powerful than the E350cdi coupe) you have to be bonkers IMHO to want more performance, and I do not drive slow.
NISFAN
Herts UK
C220CDi W204 :)
Yes the Brabus one is costly, however I would imagine that part of it's cost goes towards a fund to cover the increased risk of component failure you would get from a modified vehicle.
Unfortunately, like many performance add ons, insurance underwriters not only assess the risk of the modifications, but also put the driver into a higher risk 'level' aswell. The understanding is that if someone wants to chip their car, they are likely to be a 'hard' driver in the first place. Double whammy :(
Anyway, in order to answer your question I would have to explain a little about how an ECU map works.
Each map has a main table (a table is a group of cells let's say 32x32, if you use excel, they are laid out in a similar fashion), on one axis it will have engine RPM, and the other axis it will have reference to engine load.
When the engine is running the ECU gets fed with both analogue and digital signals from various sensors in the engine bay, including engine revs, and a measurement of engine load (MAP/MAF sensors). Also temperatures, pressures, etc etc
Hundreds of times a second the ECU plots the Speed/Load values into the table we discussed above, and where the two columns/rows cross on the map it uses the value in that cell to fire the injectors. Hope your still with me on this. :D
Sounds simple enough?..............well no it gets worse.
In order to make further adjustments to the injector pulse values, there are many more tables overlaid over the main table. These others will control cold engine enrichment, turbo boost pressure, ambient temperature conditions, actual manifold temps, diesel temperature, etc etc.
So, the final injector pulse will be the combined values after the data has gone through all the various layers of tables.
It is important to have this complexity to ensure the engine runs optimally in all possible conditions a typical engine will be subject to. The OEM's spend hundreds of hours getting these tables right.
Now, a re-map by flashing the ECU, is one where the physical numbers contained in the cells of the various tables are changed with new values. Importantly, only the values that need changing can be changed. This means that the R&D MB or any other put into getting the engine to run right at a particular ambient condition remains intact. The ECU also functions exactly as it should, the only difference is at 2450rpm and engine load 73 for example, instead of that cell containing 0.9bar turbo boost pressure it now says 1.1bar, etc etc.
A tuning box, and there are various complexities of these, generally work by modifying the incoming signals the ECU would see from the engine, in order to get a different result.
For example, the ECU controls the turbo boost pressure, and the map dictates that it should be set at 0.9bar. The electronic plug-in increases power by increasing the turbo boost by 0.2bar, so it intercepts the signal from the engine saying 0.9bar and replaces it with a signal that says 0.7bar. The ECU thinks it's running 0.2bar down, so then changes the turbo vanes and increases the boost upto what it thinks is now 0.9bar, which is actually 1.1bar now thanks to the tuning box.
The problem with the tuning box is that it is a crude device, and does not adjust it's compensations for all the conditions an engine will run in. This means it could be running dangerously close to the operating limit in certain conditions, but fine in others. More modern tuning boxes do have more complex microprocessors in them and do adjust to certain main parameters, but still not as complete a package as an ECU re-flash method.
Having said that, a monkey with a laptop can totally screw up the re-flash method too :neutral:
Sorry for the long post, but hope it helps.
jubhi
Birmingham
Thanks NISFAN for this detailed insight into remapping/chipping. Think that is enough information to put me off getting a cheap plug in Unit and maybe the only one I would consider now is the Brabus Unit as I'm sure that is probably advanced as it can get given the cost of it and MB covering you under warranty. Will wait till the Brabus one comes down in price a bit, at £2200 it seems to steep.
gfhowland
Lincolnshire
gfhowland
Lincolnshire
Thanks NISFAN for this detailed insight into remapping/chipping. Think that is enough information to put me off getting a cheap plug in Unit and maybe the only one I would consider now is the Brabus Unit. Will wait till the Brabus one comes down in price a bit, at £2200 it seems to steep.
Interesting though, take the Toyota D-CAT engine - you can't remap them without a blow torch, tweezers and a chizel, but companies such as Lindop Toyota have been selling add on boxes with very good feedback for some time now. They do use high power microprocessors and measure not just the rail pressure, boost pressure and other variables too, and their power quotes are more in line with Toyota's, ie. D-CAT 150Hp goes to 176Hp, which is about the same as the D-CAT 177. So I would hazard a guess is that if you go for any re-map or external box, you choose a high quality product from a reputable company who cares as much about your car as the manufacturer.
NISFAN
Herts UK
C220CDi W204 :)
My pleasure:D
Yep, the advice I would give is to go to a reputable company whether you go the plug-in route or re-flash. There are a number of big boys in the game in the UK that seem to have the professionalism and resources required.
I certainly wouldn't use a company that uses poor english, and worse than that poor technical references on their website. The layman however is perhaps not likely to pick up on the technical faux paus made in the web site content, but could you trust a company that can't even be bothered to run their website text through a spell checker, to enter numbers correctly into your ECU. Especially when if you mixed two numbers around it could be game over for your VNT Turbo.
EStrauss
Market Drayton; Shropshire
10th Mercedes ML320 CDI
As per title...
First impressions
After putting 400 Miles on the clock very satifyed with the remap to say the leased. The power is delivered in such away that as and when your foot is down you get pushed into the seat (makes me smile every time). Smoke no i wasent worried about smoke but its been reduced on full throttle yes you get a puff but only for a second then before you know it your at the speed limit ;). the power is very strong from pulling away all the way through to the red (if required) even at 70 MPH you have the power on tap. based on normal driving there is a large difference ie power when required there seems to be little waiting for the turbo to give you that thrust its just so smooth and raw (in a strange sence).
MPG
The MPG have shown a raise of only 3 - 5 MPG but this is quite good as its been drivern with enthusiasm by me as said before yes its hard to tell as there are huge factors that can sway it from side to side but there is still an improvement even though this was not requested, more of bounus.
Town driving
as said above the general pulling power is improved from the word go. The gear change is also different at 30-35 MPH it will change up far sooner than standard. start stop is improved there is a much smoother on light throttle.
Motorway driving
Simple when you want the power its there when you do not require it its not.
At light throttle it seens to change up much quicker and smoother,at heavey throttle it is a different machine it will pull and pull and pull all of this = a scared wife and a large smile.
All in all dispite all of the negative reports from this forum its been a pleasure. And i will have no hesitation in recommending gcl tuning for remapping to anyone, I would also like to than my mercedes dealer in bury st edmunds for the car and there service.
one of the best £450 invoices ive had ! If you are looking at the brabus remaps i would reccomend you at leased get in touch will gcl or a similar comapany.
Hi David,
I read all the threads with some interest,
Would you have any further advice to someone considering a remap, as you have had good use and experience since you last communication on remapping.
Please let me know I am interested
