Viseeo mb4+ menu button not working
Majclausen
Ml320 2007
Hi everyone
I’ve spent the last couple of hours looking around this forum. But I can’t seem to find a thread with a similar problem to mine:
I’ve bought a Viseeo mb4+. Light is green, so far so good. However the buttons are either frozen, broken, or not responding. I’ve tried disconnecting the device, holding down various buttons etc - nothing!
Both the car and my phone is registering the Mb4+ but since the menu button (along with the other two buttons) is not working, I can’t put it in pairing mode.
I’ve attached a photo, showing the display.
Any ideas?
Thanks in advance
Maj
Botus
S500/2010/500
what car is it fitted to? and have you actually read the manual
page 8 dip switch settings is a good starting point
and before that flash with firmware MB-4+ from 4 August 2014 MB-4+ CPU Update Ver.1.019 released
  • mb4Viseeousermanualv17.2206816844.pdf
  • MB-4-CPU-Upgrade-Instruction.pdf
  • MB-4+_v1.019_20141118181841.zip
Majclausen
Ml320 2007
Thanks so much for the reply and attachments :) I’ve read the manual and set up and downloaded everything. I have both the firmware and CPU update that you mention. I feel like I’ve tried just about every trick on the internet these past couple of days ;D For now, my only logical conclusion is that it must be faulty!?! Oh, and the car is an Ml320 from 07.
Majclausen
Ml320 2007
Look
Common issue. The unit needs to be opened up and the key pad realigned/secured.
THANK YOU SO MUCH :D there is still hope ;) I will try that!
