vito 110 cdi dash lights.
vito26
nofolk
vito 112
hi there did you get the fault sorted as i have same problem with mine? any help would be great
iamwills
birmingham
vito 2001 110cdi
hi was reading your post and u sound like the man that nose . i have a vito 01 , 110cdi, can the oil sound be turned of , oil is fine just beeps all the time , and going to france in it .and cant handel the beeps .,,. thanks will
iamwills
birmingham
vito 2001 110cdi
Hi I'm new to the forum bought a 2001 Vito 110 CDI . need some help with the oil warning sound . it goes of a lot but oil is fine, i am going on a long trip and wanted to no if it can be turned off some how, i took the dash,[clocks] out but could not fined a little speaker, thanks
Jayessgee
2002 Vito W638 108CdI
Dash lights and fogs....again!
Hi! I am a new member from south east Wales and I have just bought a 2002 Vito (w638) 108cdi. I have seen this thread re:dashboard light permanently on and I have the same problem EXCEPT the front fog lights are permanently on when I turn the lights on. No orange light on foglight switch and when I leave the van with headlights off and foglight switch in middle (off) position, the dash lights remain on and the lights on, door open buzzer sounds continuously. I eas thinking it was the indicator/wiper assembly but haven't seen anyone write about this problem and having the fog lights permanently on too. Any advice would be appreciated. Thanks James
VinoVito'd
CONSETT
Vito 638 2.2 CDi
Hi all, resurrection time.
I have a 2002 Vito 638 with no central locking.
The guy i bought it off was a clown and hid everything from me. I've learned my lesson.
Illumination cluster was kaput. Lights on, buzzer sounding, speedo knackered, etc. noticed a black wire behind the clocks to illuminate the odometer. Anyway, i bought new clocks and a new ribbon and sorted this problem, but lights still on a buzzer sounding.
I've put a switch on the fuse to disable the circuit when i get out. I'm thinking it's the headlight stalk??
Fog lamp lights up, and lights work front and back. Is in the middle position. they seem to work fine.
Can the headlight stalk be repaired or at least positively diagnosed?
Cheers.
Vr46mm93
V220, 2000, 2.2
Did you resolve this James?
Vr46mm93
V220, 2000, 2.2
Cheers.
Did you get a solution to this mate? Thanks
