Vito w447 drivers pre-fuse box 100amp power steering fuse
StevoAmigo1
Mercedes e350 amg bluetec
Hi guys, just after some much needed help,
I drove through flood water on a trip out last night and straight away the power steering went and threw an error light in the dash power steering malfunction check owners manual, I have done a scan with xentry and it says there is no power to the power steering ecu and to check the 100amp fuse under the drivers seat at the back of the battery, so that's what I did and noticed this fuse but I did not want to try sliding it off incase I broke it, how do I check the fuse to see if its OK? It seems like it's welded to the main metal board :S
Sent from my SM-G990B using Tapatalk
As you’ve got one end off, use a multimeter on Ohmn setting and check across it - should be 0 ohmn
StevoAmigo1
Ok, doesn't the battery need to be on for that? As had to take battery off to get to the fuse board, or will I need a special voltmeter? Also if it is the fuse blown how can I change it as it seems to be pressed into the metal board, I was thinking of drilling it off and replacing it with one of these with a tiny nut and bolt to secure it back on the board. Thanks
asimf43
A class W176 2018
Hi StevoAmigo1,
Did you manage to get this sorted? I drove through some flood water in my A class and my power steering has stopped working and the power steering malfunction message has appeared on the dash.
Any help or advice would be appreciated.
