w123 headlamp wipers
LevisMerc
Harrogate
W124 E220
Hi all,
The headlamp wipers on my w123 have stopped functioning. The wash function still works though. Both wipers have stopped working at the same time so I don't think it's the motors - I'm assuming it may be a relay and if so will I find it behind the instrument cluster?
Thanks for any advice.
Levi :)
You have a control unit
A 126 820 20 26 CONTROL UNIT
HEADLAMP WIPER/WASHER
number 89 in the picture in the fuse box up front
m.mycat
L
LevisMerc
Harrogate
W124 E220
Thanks Malcolm
Mines a W123 and there are only fuses in the fusebox. Will there still be a control unit somewhere?
Levi
Thanks Malcolm
Levi
I must have done that wrong :Oops::Oops:
try this
56 A 001 542 22 19 RELAY
m.mycat
L
LevisMerc
Harrogate
W124 E220
I've traced the wires and they lead to a black plastic cover which pops off to reveal a large mounting bracket with a single, lonely little relay on it.
This relay has 001 542 02 19 stamped on it. Just one digit difference Malcolm - could it be the same one or similar for a different year?
Levi :)
This will have just been an update but it is the same part, but do be sure that the relay is at fault if you can
L
LevisMerc
Harrogate
W124 E220
Brilliant - thanks very much Malcolm.
I'll get around to investigating properly when the weather is a bit more stable and I'll report my findings.
cheers :D
