Iso.sau.si
- Aug 13, 2018
- W123 1984 300td
Hey there! So ignition problems, wouldn't start when I try to crank it with the key. It will start when I go to the terminal box and connect the two terminals with a wrench tho.
I replaced the ignition switch and it didn't fix it. I don't see any fuses in the fuse box for anything about ignition, but the paper is all worn out so maybe I missed one?
The starter seems to be fine because it starts and it's pretty new. I'm pretty sure it's not the NSS.
So before I throw in a push button starter
Is there anything else I may have missed? I really would like the key to work still. But if it can't then whatever.
Does anyone have an electrical diagram for the ignition and starter ?? Thanks for you help.
