W124 230TE Ignition coil help needed
Klaus013
Malta
W124 230TE / 1986 / 230E
Need some help as I replaced the coil on my W124 230 TE year 1986 but did not mark all the wires.
Is there someone who has a similar coil that can check where these connect or else send me a photo of their coil? Thanks all.
robparker
Taunton
The two bolt connectors on the coil are different sizes aren't they, so they should only fit on one way around?
Klaus013
Klaus013
Malta
Yes, some of the wires have smaller holes and can only be fitted only to one connector. But these two wires have a larger holes and will fit to all connections and even to the earth bolt. On checking with a multi meter with ignition on, there is a voltage of 12v on one of the wires. I do not want to risk shot circuiting any part of the circuit.
Klaus013
Klaus013
Malta
Both wires Black and brown are earth points , so clamp to coil fixing bolt .
Hi, thanks, you were right. Connected them to the earth bolt and car started on first try.
