W124 280E Rear Damper Replacement
S80
North Lincolnshire
None at the monent, but there's an OM642 in the Jeep Grand Cherokee!
Maybe through lack of use (?), both rear dampers on my 280E have sprung a leak and so need replacing.
A quick look in the Haynes learned journal would suggest a fairly straightforward DIY proposition, unless there are any potential 'gotchas' of which I am unaware:( The car is non-sportline, BTW.
Is it okay to trolley jack under the final drive unit (using a scrap of cushioning wood) and lower onto 6 tonne axle stands positioned at the rear jacking points?
Cheers,
David
www.W140.co.uk&www.r129.co
