Zahid Jahangir
- Dec 16, 2017
- 300te-24/1989/3.0
when i purchased this car, i thought it was a non fuel injection, now realising its an old skool mechanical fuel injected system.
the car never came with a manual, i just wanted to know more about this system. i wanted to understand if this system has an ecu. wanted to see which components or parts are part of the fueling system.
i understand that wants you take off the airfilter housing, underneath it has the bosch CIS K jetronic system. i wanted to see what else this in connected to e.g fuel pump, any other sensors etc.
i want to try something else, so temporary i want to remove this system, and just have the inlet manifold with the butterfly valve which operates the accelerator.
i am sure a bigger butterfly valve can be purchased as i have seen an aftermarket one designed at 100mm diameter, which means more air. so this can fitted to the inlet manifold for more power. i do not have intention to turbocharge this beast of an engine which is a twin cam 3.0 litre petrol 24v of my 300TE-24 wagon!
i want to experiment this engine based on the carburetor system. no electronics controling the fuel except the fuel pump, and increase power!
any help or comments welcomed, thanx.
regards,
zahid
regards,
zahid
