W124 engine temperature and oil pressure
ShivaYash
Berlin
S124 1994 E200 (M111 engine), S123 1983 230TE (M102)
Dear all,
I am still very much learning about cars so forgive this basic question.
Driving home in London traffic last night, after a weekend on A-roads, my car's engine temperature was higher than normal, and hit the 100/120 mark on the dial. The viscous fan was working and I tried increased the revs whilst waiting for 10 minutes at a temp. traffic light, thinking this would bring the engine temperature down, as the fan would be turning faster - but it did not.
The oil pressure also dropped. The oil pressure was different when in neutral compared to when in drive. Is this usual?
Now I understand that as the temperature goes up, oil becomes thinner, hence the drop in pressure. At all times pressure was back up when the engine was revved.
The car was at this 'high' temperature for about 45 minutes. Can such temperatures cook the oil and cause it to 'fail', lose efficiency, and hence need to be changed more frequently than 12 months? At present the car is serviced every April, and I follow the schedule as stipulated by MB. I always use original filters and the correct high quality oil.
I do sub 5000 miles per year, a mix of city and country driving.
Many thanks,
hotrodder
'93 320te, '54 ragtop beetle (in bits)
Yep, oil pressure is related to both temp and rpm. Idle speed is a bit lower in D than it is in N or P. The oil pressure gauge in these only reads to 3 bar which is lower than the oil pressure is (or should be!) at higher rpm hence the gauge spends most of its time 'pegged' against the stop. Very roughly at normal operating temps oil pressure should be a min of ~1.3bar at idle, 2.2 bar at 1000rpm, and the gauge should be pegged at 3 by 1300rpm. Your owners handbook will probably state something along the lines of 0.5 bar at hot idle in gear is nothing to worry about as long as it increases immediately with rpm
Oil temps above 120C for any length of time won't do the oil any good in slow heavy traffic the oil won't be anywhere near as hot as the coolant
Are you sure the viscous fan is working properly? They always turn with the engine but when they lock up they make quite a racket due to the amount of air they shift. If you have a leccy fan(s)* in front of the rad for the aircon these should cut in or speed up above 110C as they're switched according to both aircon pressure and coolant temp. Switching points in the cooling system are here http://www.w124performance.com/service/w124CD1/Program/Engine/104/20-0020.pdf
If the cooling system is in good order and everything is working as it should be then the temp gauge shouldn't get above 100C (the line between 80 and 120) at this time of year even in a massive traffic jam. I was queuing for lights on the A20 on Fri for a good 15 mins, according to the car it was ~ 19C outside and the temp gauge crept from the usual 85ish to maybe 95ish before dropping back to 85ish again with a minute of clearing the lights
If the car gets close to overheating then cranking up the heater (and it's fan) will do a better job than increasing the rpm
* 6 pots have two of 'em, 4 pots might just have the one?
To check the visco, the thermostat opens at 87ºC and the visco fan should speed up at 90ºC so start the car and run it up to about 70ºC by a short drive then leave it running and as the 90ºC point is reached the fan should speed up. If the rad is getting blocked, then the hot spot where the flow of hot air passes through the rad to the visco coupling will be low. At 100ºC you can feed a carrot into the fan and it should chop the carrot up, if it stops, then a new visco coupling required or the rad is blocked. In very quiet conditions you can hear the bi metal strip that fully engages the fan can be heard to click.
And yes at very low RPM the oil pressure will be lower, and worse when overheated as the oil thins.
WDB124066
1996 E320 Sportline Cabriolet X 2
^^ That right! :):)
