w124 estate self leveling suspension prob
benster
london
E220 estate 1996
ive got a 1995 w124 estate, the ride as gone really hard and bouncey, I had one of the struts changed on the rear, which was leaking, ive read up on this and know about the spheres and valve that adjusts the height, whats the best way to check its working is just a matter of putting weight in the back turning on and and see if it raises up, or is their another way
thanks in advance
Hard ride is almost always a bad sphere.
B
benster
london
E220 estate 1996
ye
yeah ive heard that, they've been on it from new probably so was going to change them, from what ive read they are a bit akward to get to
B
benster
london
E220 estate 1996
ye
is there anywhere on here that gives a detailed description on how to change them
robparker
Taunton
Febi ones are cheap, if you are planning to keep the car a long time I'd buy them from Mercedes
B
benster
london
E220 estate 1996
i don't suppose you know how much the merc ones are, I checked out the febi ones and they are £75 on-line
robparker
Taunton
I bought 5 Merc ones for my 6.9, which are basically the same as the 124 ones, and I think they were about double the price of the febi ones, but I have no regrets in the job being done properly and lasting longer, depends how long you will keep it really
B
benster
london
E220 estate 1996
well, can't ever see me selling it, so will try and pop into merecs and see how much they come out at, do you think the really last longer then the febi ones ?
robparker
Taunton
Only from internet reads, not personal experience. Febi are a good brand
B
benster
london
E220 estate 1996
B
benster
london
E220 estate 1996
yeah I thought that, and as money is a bit tight im going for they febi ones and do it myself
don't suppose anyone knows how much fluid it takes to refill the suspension and other then mercs where to get it from
thank you
thank you
The fluid is CHF11S - available from most good oil suppliers and the usual GSF/EuroCarparts.
B
benster
london
E220 estate 1996
thanks very much just ordered some and hopefully fit the spheres next week and hoping that will sort the really bumpy ride
Almost certain to. The way the system works is similar to the old Citroen oleo pneumatic system where the ride height is controlled by system pressure in a strut and springing is provided by compressing gas in a sphere by pushing hydraulic fluid through pipes. Quite a simple but clever system.
B
benster
london
E220 estate 1996
  • #17
thanks for that I'll get it done and report back in a couple of weeks, hopefully with a lovely smooth ride
om613
london
S202 C250TD, S123 240TD
thank you
About 2L will do it.
om613
london
I found no evidence against using LHM, as it's mineral based and of very similar viscosity. But green!
So no problems henceforth, in the next 25K on my S210 (power steering shares the SLS fluid).
ISO 32 'tractor oil' would likely be fine.
B
benster
london
E220 estate 1996
  • #20
thanks for that, I bought 2L will be doing it in the next few weeks
www.ckinsurance.co.uk
