hotrodder
- Oct 18, 2008
- '93 320te, '54 ragtop beetle (in bits)
Doesn't sound like the seller, his mechanic or the MOT guy understand how the system works.
The 'shock absorbers' are actually hydraulic rams/struts and the damping (along with much of the 'springing') is handled by Citroenesque spheres. As said, the system differs from the Citroen in that it also has coil springs too.
A hard/bouncy ride is the classic symptom of knackered spheres... over time the nitrogen leaks out and/or the diaphram that seperates the gas from the hydraulic oil splits. Result is a loss of damping and compliance in the suspension. They won't cause a scrapping noise but there's plenty of other things that could...
Sphere's themselves typically last for around 100k miles max and are around £60/70 - £90ea depending on source. There's an access panel in the boot floor immediately behind the back seats and ahead of the third row seats/under floor compartment. Corrosion to the hard lines (as well as fuel and brake pipes) and unions is common, particularly around the back axle where access to replace them is complicated by the subframe
Your best bet would be to have the car looked at by an MB specialist/indie as many mechanics won't be familiar with the suspension layout on these
