w124 fuel tank
chicisles
Car will not start, I will be checking fuel pump and filter. On the bottom of the tank there is a grommet which is leaking but no smell of petrol???
When you turn on the ignition you should hear the pump running whilst priming the system for a few seconds,if it does run and stop,it is probably OK as that would indicate that it is pumping.
malcolm
Stircrazy
These fuel tanks develop leaks from where the filler pipe joins the body of the tank but if it is leaking you would obviously smell it.
What makes you think it is a fuel releted failure to start?
Unless the tank is empty of course!
Silver Arrow
Check the big relay on the bulkhead in the engine bay.
Siemens 72UD406.
kth286
E320 Coupe 95
You need to be more specific about which model you have got as there were several DIFFERENT engines and control systems.
C
chicisles
Thanks for help, the car is a 1993 e220 auto. The fuel pump relay showed some sign of corrosion but I can hear it priming under the bonnet but no sign of life at fuel pump. How can I check 12v at pump since relay shuts off power when car is not running.
You could slacken the gland nut where the pipe from the tank goes into the fuel distributor and turn on the ignition where fuel should run out.
I do have the pin out to run without the relay, I will find it
C
chicisles
I have replaced the fuel pump filter and relay, cleaned the fuel injectors, car offers to start then dies, what is next???
turnipsock
Port of Menteith
Try to start it then take out a spark plug and see if there is any petrol on it.
You can also try turning over the engine, with the spark plug connected and grounded, to see if there is a spark (best done in low light and don't hold it with your hands)
wireman
lancashire
Be very carefull in attempting repairs on both fuel and ignition systems simultaneously.
