Trying to iron out some running rich problems and one of the things I thought about looking at was the O2 sensor however my car does not seem to have one it's a 1989 300se is this normal or am I looking in the wrong place?
As a 1989 car it most likely has mechanical fuel injection (or possibly even carburettors) so has no ability to use a Lambda sensor to control mixtures.
If it has electronic fuel injection, it should have an oxy sensor.
If it has a carburettor, you will have to adjust the settings of the carb to get the right fuel mix.
Carburettors work autonomously (opposed to adjusting constantly from feedback signals from sensors) so the ‘correct’ fuelling is basically down to the opinion of the mechanic.
The most feedback that old-school carburettors have is vacuum lines, so maybe one of them is blocked or split? (If it has that)
Yes it does not seem to have a catalytic converter so it doesn't have the sensor in which case how do I adjust the air fuel mixture correctly? I have ordered new distributer cap and rotor arm,also plugs and wires. Once done I need to look at the mixture.
There should be various screws on the carburettor to adjust the various characteristics (idle speed, idle mixture, damper etc) check a diagram of that particular carb to find out which screw you need to tweak to alter the fuelling. I think idle fuel and idle speed are different screws though (unless my memory is failing)
The K-jetronic injection system has numerous adjustments however you need to be careful as you can seriously affect the running of the car if you don't know what you're doing.
You also need to be sure you aren't simply adjusting something to mask a fault condition.
I'd suggest taking it to someone familiar with K-jetronic injection systems.
WE HAVE NOW MOVED: 8 Hazel Road, Woolston, SO19 7GB Service, Repairs and remapping service Any queries, please do not hesitate to contactEmail@mbsofsouthampton.co.ukor alternatively you can phone Colin or Dave on 02380 445820, out of hours numbers are 07787913313 or 07907631681.
