W163 Inlet Manifold Lug Damage
ldare
Swansea
2003 270ML Inspiration / 2007 R320 Sport
Hi
I noticed lots of wet oily **** under my EGR and on closer inspection there was quite a gap (at least 5mm) where the lower of the EGR meets the Plastic Inset Manifold.
As I started to undo the bolt I could see the metal lug through the gap turning too.
Ive now removed the EGR, cleaned, inspected and fitted again (as I need to use the car still).
Am I going to have to remove and replace the entire Inlet Manifold? I assume there's no way to fit in a new metal lug that will cut in?
Louis
L
ldare
Swansea
  • #2
Hi I posted earlier that 1 of the 3 metal lugs holding the egr to the inlet manifold had failed. I am now assuming it can't be fixed.
I am going to have to accept I need to change the inlet manifold needs replacing.
I see two designs of gasket and I am not sure if I need one or the other or both?
Any ideas??
Ta
Louis
2003 ML 270 CDi
L
ldare
Swansea
M6 is my bet
L
ldare
Swansea
Thesr were way to narrow. Most M6 inserts are about 8mm in diameter and the mercedes ones are 12mm.
I used a 6mm drill to effectively turn the original insert into a spacer and inserted it into the hole it was from. I then drilled a 6mm hole through the plastic. I purchased a longer M6 bolt from mercedes and with a nut and washer successfully fixed the EGR to the inlet manifold at the lower of the three points of fitting where I had the issue.
Cheers
Louis
