W168 NO START
C
churchy
Hello All and greetings from sunny Australia .
I have a 1998 W168 A160 ACS bought as a non goer / project and would greatly appreciate any advise .
At this stage I am awaiting some wiring diagrams .
· W 168 A160 , 1999 Avantgarde , ACS , 182,000Klms
· Serviced by MB dealers until recently
· Service book does not display 049 in the range of codes re. the starter motor type
· Owner was told it required a new starter motor
· New battery , fully charged at 13.4V
· No volts @ the mauve/white 3 pin connector near the positive end of the battery when ign sw. in posn. 3
· When ign. is in posn. 2 all warning / caution lights are illuminated however there is no indication of gear selection ( as this is a ACS it will not start unless in neutral )
· When manually closing the contacts of the starter relay K3 , the starter activates and cranks the engine
· All earthing points in the engine bay cleaned
· The ignition switch contactor is replaced , new ,and battery recharged
· On the next attempted start all indications are normal including indication of gear selection and the engine cranks over and starts , runs for about 15 seconds then stops
· Subsequent attempts to restart give the original symptoms ie. No gear indication and no engagement of the starter motor
· The ASSYST service indicator has been reset
· The door locking system operates normally
· The key fob batteries test OK
· All relevant fuses checked OK
· ACS control module elect. connector pins cleaned
· MAFS/ECU “ “ “ “ “
· ESP/BAS “ “ “ “ “
· ABS “ “ “ “ “
· Gear selector reset carried out
· Relays K7 and K10 transposed P/N 002 542 13 19
· Relays K8 and K9 transposed P/N 002 542 25 19
Kind Regards , churchy
mattkh
England
A160 W168 1999 1.6
What sort of car alarm/immobiliser do you have on the car ?
C
churchy
Hi mattkh ,
This is an Australian delivered vehicle .... No alarm system is fitted ,
just the standard DAS , working very well as an immobiliser right now !
Thank you for responding .
star
Reading
Smart + others :)
Get the faults read, if the acs is faulty then it will not allow it to start.
C
churchy
Thanks star ,
Until I get hold of the wiring diagrams and OBD reader I am guessing that the no starting is due to a no gear selection signal being sent to the ECU ,perhaps due to one of the two switches at the gear box end of the selector cables .
Just a bugger to access , but will check out their operation .
I appreciate your response . Cheers
