W169 A150 – interior light cluster – problem
AndrewCS
A Class W169 A150 manual 2006 - 55k
Greetings,
I recently bought a 2006 A150 and the courtesy light / interior light cluster isn't working. I took the unit out the roof panel and checked the two bulbs with a volt meter and they are good. I can't find information regarding which fuse it is for this.
TIA for any input on this
Regards
Andy
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Welcome, I assume there is no voltage on the cable which connects to the light assembly?
Pull the fuses one at a time check the fuses, also check for voltage on the fuse holder.
one of the fuses will be live with the ignition off, that’s the one you are after.
A
AndrewCS
Thanks for your reply. Quite a job to pull every fuse, was hoping someone would know which fuse it is, even an indication of what amp fuse would narrow it down. Cheers. Andy
A
AndrewCS
Now solved
Thanks again for replying to those that did.
I took the car to my friend that has a diagnostics tool and it came back everything clear. I took the overhead light cluster unit out and took it apart, inside is a PCB with quite a few ICs. I decided to take a chance and ordered a 2nd hand unit on eBay (made sure same part number) and it works.
Thanks again for your responses.
mattkh
England
A160 W168 1999 1.6
.........inside is a PCB with quite a few ICs. I decided to take a chance and ordered a 2nd hand unit on eBay (made sure same part number) and it works.
Please put up a picture of this PCB. Many thanks.
mioba
Nottingham and Köln
As a side you dont need to pull fuses to test. They have metal points at the tops to put your continuity probes on.
Glad you are sorted.
