I don't have pictures of my own mirror's back, so here's one from eBay:
If the sensor is clear of any obstruction, and clean, then check the connectors (the yellow one here) and wires for damage, and maybe clean plugs with contacts cleaner:
In the mirror assembly:
And inside the OCP (the one on the right, with pink, brown and blue-yellow wires):
Thanks for this post. It's my intention to install a dash cam in the next week or so and just behind the mirror is the obvious place for it. doh!
Yep, one of the reasons, mine is on the passenger's side ...
Which reminds me - it's over six years old now, so I ought to start looking for a replacement.
The problem arose when I fitted the dash cam to the right of the mirror. Fitting to the left is no problem except that space is a bit tighter. Still it makes the cam less visible from outside. There are some nasty people around who would have it away if they spotted it. Also I covered the shiny bits with black tape. Paranoid? No.
I actually modified my BlackVue DR400G-II quite heavily - perhaps that's why it is still working perfectly fine, six years on.
I removed all the chrome bits, including the lens surround (built my own); modified (slimmed down) the holder; fitted a permanent CPL; drilled four (or was it six?) holes for better ventilation; blackened out side button LED; and finally, wrapped it in carbon fibre vinyl, including the holder.
It's hardly visible from the outside, and as I said - worked perfectly fine in my old car since Spring 2012, and now for over three years - in the current car.
On the topic of dipsey mirrors (well not too off-topic I hope...) does anyone have a remedy for an unwanted tendency for severe automatic dimming during a combination of roof down/low winter sunshine cruising?
Recently, driving East, enjoying a lovely evening on the M4 my mirrors were virtually black. Can their 'dimming' function be disabled by the driver I wonder? (No. I did NOT decide to go quick enough, to reduce any danger, to the point that there would be no possibility of anyone catching me up!!)
