W202 Ignition key won’t turn past 1 or 2
Dec
Ireland.
W202
Update, the fault was wear on the inside of the brass levers inside the lock barrel. It is not possible to remove the levers from this ignition lock as there is some kind of anti-tamper built into the levers in the lock barrel preventing there removal.
Normally the only remedy for this fault is a replacement ignition lock barrel, however there is a simple solution to this fault, the removal of about .020 to 0.25mm from the top of each lever in the lock barrel using sandpaper, this compensates for the wear on the inner part of the levers and cures the fault.
Symptoms;
=Key won’t turn from position 0 to position 1…not to be confused with the steering lock preventing you from doing so.
=Key won’t turn from position 1 to position 2
=Key won’t turn from position 2 to position 3, (3 being START) in an intermittent fashion without several attempts.
=none of the above, however, if very occasionally…with the gear stick in P… it is necessary to turn the key back to 0 because it sticks at one of the above numbers then this could be indicative of the beginnings of this fault.
Unfortunately, occasional sticking of the key goes unnoticed until this fault happens and it happens quite suddenly, it’s only then, that those previous sticking events begins to become relevant.
Cause;
Wear on the inner edge of the brass levers inside the lock barrel, the wear is caused by the “sawing” action of the key blade as it enters/exits the lock.
Cure;
Remove the ignition lock barrel and remove approximately 0.20mm to 0.25mm from the top edge of each lever with sandpaper, this is not an easy amount to measure, so like me you will have to guess, as a guide, a credit card is about 0.75mm in thickness.
If you experience any of the above symptoms, the ignition barrel should be removed immediately. If the key can’t be turned to position 1 then the barrel can’t be removed, as far as I know, without its destruction.
Note; the above refers to a 1994 W202 C180, it may or may not be applicable to other models. Other models may have a different method for removing the lock barrel.
This is an easy job to do, it cost very little and takes under an hour. “If it ain’t broke, don’t fix it” is a good rule to follow but in this particular case a little preventive maintained is wise and it’s an opportunity to lubricate the lock.
Ignition lock removal video… http://www.youtube.com/watch?v=nkM-Z1vuaJw&feature=channel
Dec
D
Dec
Ireland.
W202
  • #2
Contd.
Slowpoke
Could you not just swap the boot and door barell? Having a similar issue but am a lazy git.
D
Dec
Ireland.
W202
No the are different so not interchangeable, you could however swap the passenger side lock BARREL over to the driver side or have a go at fixing the driver side fault, assuming that is, that it is a similar wear fault to the above. I assume it is your driver door lock that is faulty?
Dec
attachment.php
D
Dec
Ireland.
W202
The passenger side lock is rarely used so it is unlikely to be worn, more likely seizes due to lack of use, repeated flooding with WD40 in the lock keyhole will free it up.
The door lock barrel is completely different to the ignition lock barrel and not as simple in that the leavers do come out of the barrel, will put up a couple of pictures of how it comes apart tomorrow.
Dec
D
Dec
Ireland.
W202
If the key has always been the only means of entry to the car then it will likely be wear. The ignition lock will also have had the same amount of use so worth checking that out too.
It’s important that the passenger door lock is in working order in the event of a failure, for whatever reason, of the drivers side lock.
See also… http://forums.mercedesclub.org.uk/showthread.php?t=53189
Dec
If you wish to discuss this thread please post replies here
www.ckinsurance.co.uk
