With my 203, it's the slow engine warm up that's the pain. I need 6-10 miles before the heater begins to work normally. Once 85 degs shows, it's rock steady and the heater works fine.
Hi sorry to butt in, I have a Mercedes ML 270 cdi Auto 2002 model. The heat has gone in the cabin, the engine temperature on the dash was indicating and hovering around zero. Someone on the forum suggested that my thermostat needs changing.... I first decided to drain the old water, I then refilled with plain cold water and run the engine for 10 minutes, I repeated this process twice....As the thermostat was stuck in the open position, the flushing process was done COLD, as the engine never really heated up....I then drained the water and went about changing the thermostat ( WOW!...that was fun ) , what I did not know was that at the underside of the thermostat had a rubber tube with a metal insert which fitted into the thermostat and the engine....after thermostat was fitted the (new antifreeze) water was gushing out....I found out that the insert was lying on the engine block .....After that was rectified, I topped up the lost antifreeze and run the engine for 20 minute....I occasionally give it some revs for a minute or two whilst squeezing the hoses, and even took it for a short drive with the cap off to bleed the system, but....the heat in the cabin was still zero (non existence), however the engine temperature was now hovering at approx 89 degrees, this indicated to me that the old thermostat WAS actually faulty.....but still no heat!!!You can get blockages around the heater matrix. We have had a good few 203's with this. You have to back flush it (from drivers side to passenger side)
I also have two 1000cc sporting Vtwin motorcycles, each has two radiators, the car's Aux Rad is about the same size as one of the bike rads. One of the two bikes produces nearly the same power as the car, so one of it's rads can dissipate the heat generated by some 65 BHP.Thank you so much for that... really informative. That aux radiator is larger than I'd expected and... together with its to/fro pipework... I can now see how it could lose a lot of heat.
Hi Rory, My car does have the heater booster but I have disabled it using the dash settings. The owners manual suggests that not using it will save fuel! I didn't question it at the time, twas Summer, and therefore of no relevanceOne regular journey I do is 23 miles of rolling A road to the M6, and it takes nearly all of those miles to get the temp to its normal reading. Once it gets there, mine is rock steady though at a shade under 85C - doesn't matter if it's freezing cold or I'm stuck in a jam on a hot day. I've always believed it's a normal direct reading analogue temp gauge but I'm not 100% on that. I've had the car since it was 6mths old and it's always been the same. The electric heater booster in the block works fine on cold days - I get warm air within a few hundred yards.
Interesting to compare to my wife's VW Tiguan with VW's latest (EU6) 2 litre diesel. The has a false temp gauge which gets its output from the ECU, so it's at 90C in 3 miles and apparently VW designed it to never budge from that unless the car seriously overheats. However the cluster computer can display the oil temp, and, same as my car, that takes in the region of 15 miles to get to 90C.
It is electrical, correct? And is just a 12V electric heater, so, by helping to heat the interior it should allow the coolant to warm a little more quickly and, by adding some extra alternator load, give the engine a touch more work to do, also help warm up generally.
Will using it consume more diesel? If it does will it by be enough for me to notice?
OR
Assuming that I go far enough to get things up to temperature, will it save a little by speeding the warm up? Again, enough to notice?
1.7kW would be about 140A by my reckoning.
I got mine from the main dealer here in Exeter, they took a little persuading that my car had such a thing fitted though! The part number of the one I used is A 005 203 3975.Well, I can't find anywhere to buy this part on line. Anybody have any ideas? I'm in Surrey.
