W203 driver's side window problem - something broken?
drivencrazy
W203/2003/2.7L
Hello everyone.
I pressed the button to lower the driver's side window.
It lowered to the bottom of its travel (i.e. right down)
Then there was a metallic 'click' or 'boing' like a piece of metal breaking or snapping
Then the window went straight back up instantly
Now, on bumpy roads, there is a sound from the driver's door like a a small piece of metal rattling around.
I have not tried to lower the window since the above in case it stays down.
All thoughts or suggestions on whether there is a problem, the likely cause, remedial action, parts required, etc., will be very welcome.
Thank you.
Sounds like part of the window regulator has come adrift. You’ll need to remove the door card and have a look at what’s come off and take it from there.
I’ve changed window regulators before and they can be a bit of a pig but as long as you’re careful and take your time it’s definitely do-able. Just take care around the glass and make sure you don’t tear any waterproof plastic when taking the door card off.
umblecumbuz
Wales and Gozo
Fading 203 memory, but ... I seem to recall that there is an aluminium panel covering much of the inner door once the door card has been removed. It is riveted into place, and has to be drilled out. If so, it has to be removed before the window mechanism can be accessed.
My memory is hazy, and what I've said here might only apply to the later model - 204 class.
D
drivencrazy
W203/2003/2.7L
blobcat and umblecumbuz - thank you very much for the replies - this is very helpful.
