W203 Engine Rattle at Idle
Ben1998
Hertfordshire
C200 CDI 2006 (W203)
Hi All,
This is my first post, so not sure where to post it. I have a 2006 W203 CDI. Yesterday I noticed that when I come to a stop the engine seems to be vibrating much harder than usual, causing a buzzing/rattling sound inside the car. It sounds much like the engine is shaking and rubbing against something. If I lift the revs (even by 100 RPM) the sound goes away completely.
Obviously I have looked under the bonnet, but it doesn't look or sound out of the ordinary.
Any help will be appreciated. I was thinking it could be engine mounts, but not sure if it would come on so suddenly?
Thanks.
John Laidlaw
Wirral
Land Rover Discovery 4
Welcome!
Engine or gearbox mounts would be my first check, they can seem to suddenly come on, as wear accumulates
B
Ben1998
Hertfordshire
Thanks for your quick reply! The car is already booked in (to have the handbrake cable re-clipped, diagnosed from the forum), so I will mention this to them when it goes in. In the meantime I'll have a look to see if I can see any obvious damage around the mounts. Hopefully it shouldn't be anything too expensive!
