W203 Fuse Diagram
DY2
Bexleyheath, Kent
W211 2003 E320 Cdi Automatic
Thought Id upload a copy of the fuse diagram for the w203.
Mine was missing from my car, and I noticed a few requests of past for people requesting this.
So for anyone that needs it, Scanned from the Haynes Manual.
Dan
Thanks Dan,, one big problem is that there are 3 changes to the layouts in the cars life, no doubt it will help many
wildmann
flintshire
c240 elegance 2001
Hi Television,
I've just found that my green fuse diagram has gone walkies! Car returned from the garage, 2 different auto electricians..no one responsible! Silly question, but being a novice...although the diagram that you have uploaded is for a W203, will it be ok for my C240 2001 W203? Also, would there be any way of making it slightly clearer, or can you point me in the right direction so that I check out others. It might be better if it was emailed. I can let you have my email address if this is possible.
Many thanks.
wildmann
flintshire
c240 elegance 2001
Damn, people are good on here..fantastic!! Such a fast response...many, many thanks.:D
One other question if I may.
My vehicle, C240 W203 recently(Sat 5th Feb) had the module under the drivers seat replaced due to the dreaded drain. I turned my radio on yesterday and selected CD..only to be told...No CD (!) I have a MB six stack situated within the glove box..still fully loaded, and I can eject the casette that holds them..but no music. The green lights are not on, although the green light does come on when the cassette is ejected. ?? Any thoughts?
I've got the garage that did the repair looking tomorrow..but would be good to be informed.
Oh, by the way..my passanger mirror also now refuses to go into park mode..unless put there manually..it'll correct itself when I select drive though.?? Any thoughts on this?
Both of these things have happened since the car was repaired/returned
Many, many, thanks
If the battery was disconnected when they changed the seat module it could have all locked up, and a reconnect will be a possible cure
wildmann
flintshire
c240 elegance 2001
Thanks Television..got my car back yesterday..all is well. They didn't tell me (I should have asked..I shall endevour to find out next time I see them and will post answer) what the cause was, but I shoud imagine it's probably what you say. A quick scan and a reset maybe. As I say will post.
Now need to get some cash together for two rear tyres and a service! Nothing but expense, but hey, that's cars for ya.
Many thanks.:D
leopoldorbm
brazil
c320/2001/v6
I urgent need pinout for MB c320 2001 A0305455832
Does anyone can save my life with this favor?
Thank you in advance
Please say what the ECU is or does.
