Some cars give odd live values with a stored code.
What codes do you currently have?
Also, you may be monitoring the air filter map sensor.
Hi yes a icarsoft cr plus .. wiring to map sensor seems okIs the wiring and connector OK? Generic readers don't always give the right definitions. Do you have an Icarsoft?
Is that what Icarsoft is giving you?
OK will double check..I have changed map sensor. But no joy.Ah OK, I'd check the that sensor and do double check the wiring! What are the other codes?
Did you get attached pics above?What are the definitions for those codes.
OK thank you very much.. as I say I've replaced 1 map/boost sensor.. which is the most exessable one ..but is the 2nd one just at the back of that 1 on 250cdiAh yes. You potentially have a boost leak, but do check that poost pressure sensor, I think it's the same as the other sensor (there are 2 on the twin turbo engines). See if the fault follows the sensor or not.
Brilliant thank you for all your help .I'll have a look tomorrowYes they are both quite close, just lower and behind.
Do sanity check the wiring though, the sensors don't fail that often!
Just out of curiosity are the icarsoft cr plus good on the mercs?Yes they are both quite close, just lower and behind.
Hi Alexander ive had a good root around the wire harnesses can't really find any thing that stands out... so did a live diagnostic stream... I noticed boost pressure sensor was 0.80 bar on tick over ...and it stayed the same when reving engine .. is that correct?? Thought the psi would increaseYes much better than generic readers.
Many thanks for your help.. I'll have a look again tomorrowDid you check intake manifold? Sometimes they can crack and you have to replace them. At this point I would suggest to take it to the Mercedes Dealer or a good indie that will be able to perform some more tests on SD. I will try to run SD in Test mode to see what type of checks SD is recommending for the error codes. More than likely it will ask to check the voltage on the plug to the sensor and for the intake leak error it will ask to perform a smoke test.
Did you have any error code which was relating to DPF pressure sensor?
