W204 doesn’t open trunk from remote and interior button
Hripsi
Mercedes e220 cdi
I have a w204 c220 2008 and I am having an issue with the trunk. I can only open the trunk manually by sticking the key into the keyhole and turning it, then opening it normally. However, I can't open the trunk with , the button on the key, or the button on the driverside door. I can hear the mechanism moving, but the trunk doesn't open. I have disassembled the trunk and replaced the trunk actuator (with a used one from ebay) and the same thing happens.
Barnesautos
W245 B170 petrol
Check the wiring is not frayed on the boot lid hinge area , could be giving a poor power or Earth and not operating the actuator enough to open the boot.
andynpz
CHELTENHAM, GLOS.
2017 GLE 350d, navy-blue, --- SWMBO's car, 2007 SL 350, (R230) silver.
or do what my pal did - turn key as far as possible in the other direction, then remove it
H
Hripsi
Mercedes e220 cdi
When i turn key as far as possible it can’t remove.
mattkh
England
A160 W168 1999 1.6
Can you hear the mechanism moving?
Now the actuator moves, right.
Is there a cable attached to the actuator? Is the cable jammed?
